First cut filter. Didn't see anything crazy.
2019 Ram 1500 Classic, 5.7L, 56300 miles
Thanks, man!First cut filter. Didn't see anything crazy.
View attachment 153799View attachment 153800View attachment 153801View attachment 153802View attachment 153803
PP was used from 16500 to 56300.What oils have you been using? Did you put PP back in? Would be interesting to see a run of HPL followed by a filter inspection.
The Oil is more important than the Oil Filter, Good Luck with the HPLPP was used from 16500 to 56300.
HPL PCMO was put in with an Amsoil filter. Having some regrets about that filter currently, but going to plan to pull that filter at 5000. Filter cut is planned.
Very nice pictures. Thank You for cut and postFirst cut filter. Didn't see anything crazy.
5W20What grade of oil was used for this run?
Will definitely be curious to see what happens in the filter after this first 5000 miles and then the second 5000 miles. Probably won't use the Amsoil against since Amsoil saw issues with overloading the filter on this engine.The Oil is more important than the Oil Filter, Good Luck with the HPL
I haven't tried. Maybe I should on the next change, but I don't see it squeezing in there.I assume, and I think I asked you before, but the larger EaO11 wouldn't fit, correct?
It's tight on the DT, but it does work. Not sure about the DS, I think on some it fits (tightly) on others, it doesn't. I have to go in through the front, and it's snug, but fits.I haven't tried. Maybe I should on the next change, but I don't see it squeezing in there.
Is that the Fram XG2?
I'm usually going through the front. I'll grab an XG2 along with a XG10060 next time I need a filter.It's tight on the DT, but it does work. Not sure about the DS, I think on some it fits (tightly) on others, it doesn't. I have to go in through the front, and it's snug, but fits.
W/O metal mesh ? Thanks for post .First cut filter. Didn't see anything crazy.
They cut that out several months ago. I believe that the Endurance at Walmart is now the one with wire mesh for a couple dollars more. For now lolW/O metal mesh ? Thanks for post .
