I disagree. First the Microgard Select is rated at 99.9%@25, 99.5%@20, and 98.7%@15 microns. Secondly I measured the leaking gaps each at .75”x.020” conservatively. The leakage was substantial when calculated in that thread. Which also showed up with particle counts worse than a Boss.Well, not quite.
Here's why it doesn't bother me much: the media of the Ultras is good enough that the fraction that DOES go through the filter is sufficient to keep the oil pretty clean.
I posted about this elsewhere, but let's say for purposes of illustration that an Ultra is leaking 20% of the flow through a defect. That's an unrealistically high number based on the huge amount of media flow area vs the tiny pinch of leakage, but let's stick with 20% just to examine the seriousness of the leakage.
Ultra media is 99%+ at 20 micron. Let's say the it's only 99% or ß100. At 25 microns like other filters, it's might be ß500 or greater. Certainly at least ß300.
The Microgard Selects that I use are rated at 25 micron and 99% or ß100.
Because the base media of the Ultra is rated at 5 microns smaller, the effective efficiency at 25 microns will be at least triple to as high as 10x or more greater than the microgard at the same 25 micron reference point
So if the Ultra is merely triple the efficiency at 25 microns, it means that the internal leakage of the Ultra would have to be on the order of 66% in order for the ultra to be merely as good as a Microgard Select that doesn't leak at all.
Based on the posted "flashlight test" pictures I've seen, there's not the remotest chance that 2/3rds of the flow is preferring to go through that crevice instead of all that media area available. Which means that even a leaking ultra is still as good or better than many other good filters on the market.
The fact that visible particles are seen past the gaps debunks two theories. First that not much oil is bypassing the media and second the multi-pass cleanup theory. Even the known low efficiency filters don’t show visible particles in the center tube including cleanable racing filters. It honestly alarms me that some are still ok with visible particles on the inlet side of the media.
