Originally Posted by ZeeOSix
Originally Posted by Vern_in_IL
That center tube.... got some worn punches in the tool.
Unacceptable for an "Ultra" Holes should have no hanging chads, and louvers should be fully open. It looks like they are running the tools longer before cleaning/rebuilding.
This is what happens when your company is restructured in Bankruptcy.. Run lines longer, extend tool maintenance intervals. Champion Labs/UIS/Carlyle Group/United Components/Fram/whatever else they're calling themselves these days, UCI Holdings.
Those things that look like louvers are normal, and part of the manufacturing process. Motorking explained it a while ago. I wouldn't call a little flare on the center tube holes any issue, the metal isn't going anywhere.
To me, those x's visible in the holes look like the wire mesh backing supporting the media in the Ultra, not metal burrs from dulling punches ...
It is the wire mesh media backing you're seeing through the holes. I think he's talking about the slight flare on the edge around the circumference of the hole - technically not really a "hanging chad". Just a rough punched hole with a little flare on the edges - it's visibly not perfect looking, but no metal on the hole edge is going to "break off", nor from the rectangular areas along the center tube seam that look like louvers.
Definitely not Louvers bit the holes are poorly punched leaving burrs that could break loose.
Glad to hear from op that the seal around the center tube where the leaf spring bypass valve fits in looked good.
Sorry though, it shouldn't get a pass on the dangerous burrs do to sloppy manufacturing no matter the manufacturer
