- Joined
- Sep 1, 2024
- Messages
- 846
FWIW, and as wondered, possibly expected, the latest PH3614 is no longer the same. It has the Champ plastic cage center tube and Champ date code. A base plate like I have never seen before, different, big flat area around center with a 3 stamped. So not cutting it open yet. I like it a lot for $4. Looking in with flashlight I see what looks like whitish felt material, very thin band around bypass valve. So it’s probably not metal end caps, perfect for not leaking. It’s also about 3/8” or so shorter than before, and the can flutes are deeper and different. Product of USA on dome. Doesn’t say made in. Put finger inside, no burs on threads, no dirt seenby eye inside.
Maybe TG will be changed or already is.
Update, on last pic I noticed adbv is looking off to one side. Sure enough it is, and I can see a gap, not sealing. Big fail. Huge fail. Adbv must not be centering on that big flat are. OMG this is amateur. From flowers to mud in one minute.
