MrQuackers
Site Donor 2025
This filter was run for 5k miles on a 2004 GC SXT with the 3.8 liter engine. The vehicle used about a quart of oil per 1500 miles. The vehicle has 222k on the odometer, runs great. These vehicles just have a reputation for using oil.
The media looked very solid. The engine must be in good running order as I did not see much of anything. The manual says max change interval is 6k. I think severe service was 4k. The ADBV seemed quite pliable for nitrile at 5k. One oddity, the filter gasket was stuck to the engine. Always check for the gasket when you change the oil! Take your time, have a beer
This particular OCOD seems just fine other than the gasket issue.
To anyone thinking of cutting open a filter, I recommend first cutting a small section and then letting it drain for a spell. You would be surprised how much oil is hiding in the filter. Less mess! Anyway here are some pictures, sorry not the best quality.
YES I USED A HACKSAW
