Originally Posted By: 440Magnum
Originally Posted By: ZeeOSix
Originally Posted By: mrsilv04
Well, you've changed two variables... the filter *and* the oil.
Hard to tell at this point, as to which one might have caused the change in what you're seeing at the pressure gauge.
My bet is the oil is what changed the oil pressure. With a positive displacement oil pump the flow resistance of the oil filter isn't going to effect the volume of oil coming out of the oil pump.
If oil pumps were *truly* positive-displacement, that would be true. But they all have rotor tip and rotor side leakage, and in most cases the relief valve is between the pump and the filter.
If the oil pump is in good shape, the rotor leakage isn't going to change anything enough to see any effect on oil pressure based on what oil filter is used. I've used 4 or 5 different brand/model oil filters on my Z06 and I've recorded oil pressure vs. oil temperature and engine RPM for all of them. They all give the same exact oil pressures throughout the RPM (idle to 6000) and temperature (50 to 220 deg F) ranges using Mobil 1 5W-30 full synthetic oil.
The relief valve should only start bleeding off oil volume at high RPM with hot oil, thereby controlling the oil pressure supplied to the engine. Most engines have oil pressure gauges located after the oil filter, so you can't directly see the effect of the oil filter. But besides, there will typically only be +/- a couple of PSI difference in delta-p between any given quality oil filter.
On Mopars in particular, the relief valve tends to be open most of the time so that the oiling system operates as a constant supply-pressure system over most of the RPM range (notable exception: the Pentastar V6, where the oil pressure is computer controlled with a variable displacement pump and will suddenly drop from 80 to 40 or shoot from 40 to 80 as needed). When the relief valve lifts, you have a fixed pressure upstream of the filter, so the gauge DOES vary with filter Delta-P.
So Mopars have 70~80 PSI of oil pressure at idle with hot oil? I'm not talking about "computer controlled" oil pumps, etc ... just old fashioned positive displacement oil pumps. Again, if the oil pressure gauge is down stream of the oil filter, you will never see the effect of the filter's delat-p on the engine's oil pressure gauge - unless the oil pump is in pressure relief. You would have to place the oil pressure gauge before the oil filter to see the filter's effective flow resistance.
