Fram FE10575 C&P
Filter came off of my wife's 2017 Ford Explorer with the naturally aspirated 3.5 V6 with roughly 130K miles on the clock. It was in service for 210 days and 5,531 miles. I didn't bother attempting a flashlight test on it as we won't be using anymore Fram filters on her car but there were some pretty bad ruffles on one side of the leaf spring while the other side was smooth.
Off/Out-Fram FE10575 and 6 quarts of Mobil 1 Full Synthetic 5w-20
On/In-Microgard Select 57502 and 6 quarts of SuperTech Advanced Full Synthetic 5w-20
Just not impressed with what these look like for the price. I ran one on my wife’s Edge for 15k and won’t buy another.
OP I see you are at 130k, are you on the original water pump? I’m hoping to run the Edge to 150 without replacement.
Still on the original water pump right now. I am keeping a close eye on the coolant though. I've read that 150K is usually the upper end of the life span.
I realized later you may not have the transverse engine being an Explorer but it sounds like you do.
I have heard of some what I would consider low mileage failures and quite a few going further than I would expect. I’ve never been able to discern a pattern though. 🤷
It is the transverse engine. I've heard the same but hopeful that we get lucky 🤞
It seems this Fram Endurance lost some of it's holding capacity with the pleats folding in on each other
That may be. Who knows how bad it looked prior to use. Fram's pleat spacing has been incredibly inconsistent. I am switching all of our vehicles to Premium Guard sourced filters, they don't seem to have the issue with pleat spacing and distortion.
Oil is still going to flow through the filter media regardless if some pleats are tighter than others and distorted, and as it does the filter will still catch debris. So this will not affect the filter holding capacity.
Explain how you think it's going to change the filter's holding capacity.
Distorted pleats reduce filter surface area and holding capacity as seen in second picture. Here is a picture I upload for you to better understand. Notice how wider pleat can take in and hold more while tighter pleat is unable to hold any in?
That's not a good analogy. You do realize that even if the pleats look "tight", the oil still flows through them and the actual size of the particles in the oil are analogous to a beach ball going into the Grand Canyon. The particles will still all be caught in the filter. If one area of the filter starts getting loaded more than another, the oil will just naturally flow to a less flow restrictive area of the media and catch particles. There are plenty of oil filters where all the pleats are packed together pretty tight, especially on the ID up next to the center tube, and they have good holding capacity and perform just fine, even in terms of dP vs flow performance.
If that's what you want to believe.
That's how fluid flow works, but you can also believe what you want. Tight pleats don't really impeded oil flow through the media, nor how the media captures debris. All the oil still goes through the media and is filtered just the same.
