Originally Posted By: DarthDuty
Fram PH7317
Purolator Classic L14610
Im going to be using one of these, so no mention of ocod or tearolator will be allowed please.
Fram is a dollar more (ish), im fine with fiber endcaps, filters 95%, also has more/and bigger (flow/drain?) holes.
Puro is 97.5%, smaller/less holes, metal ends.
My biggest question is from videos ive seen, the fram has the oil go straight through lining up with the threads? (they call it a full flow lube filter on frams 7317 app lookup page.
Videos appear to show puro has only a top hole where threads are? I confused.
How long are your OCIs? Are they mostly highway or city? I assume this is going
on a car or is it being put on an ATV, 4 wheeler, etc?
Either will work. I would choose pureone myself, but I know that isn't one of your options, but for a few dollars more, I have found the Pureones To have better construction and filtration capability over the 2 you named already.
Good luck and post pics of whatever you decide to use!
