FRAM Extra or Puro Classic
I'm Running a 15- dollar a piece Honda s2000 spec FILTECH filter on my 2.5 Nissan. No chances, NO more tiny Nissan filters for me! I might run the Honda service part I have in my stash from my fit (a "properly" built FRAM
but Im North Shore aboudit.
Having run this size filter on a lot of cars, I would run the Pur-o-leaker before the OCoD - only if its made in U.S. and just Deal with the drips and dribbles.
Originally Posted By: DarthDuty
Fram PH7317
Purolator Classic L14610
Just because it is 14610 and that is the worst offender for tearing, go with anything else. If you don't feel as comfortable with the lesser fram, go with a Toughguard. I would still go out of my way to run a WIX.
Failures by model type
14610 13
10241 11
14459 8
14460 5
20195 5
12222 2
14006 2
24651 3
10111 2
14477 1
24011 1
25247 1
25288 2
30001 1
Fram would be my choice. Decades of trouble free use and multiple cut and examined filters have earned my trust.
Fram PH7317
Im going to be using one of these, so no mention of ocod or tearolator will be allowed please.
Fram is a dollar more (ish), im fine with fiber endcaps, filters 95%, also has more/and bigger (flow/drain?) holes.
Puro is 97.5%, smaller/less holes, metal ends.
My biggest question is from videos ive seen, the fram has the oil go straight through lining up with the threads? (they call it a full flow lube filter on frams 7317 app lookup page.
Videos appear to show puro has only a top hole where threads are? I confused.
How long are your OCIs? Are they mostly highway or city? I assume this is going
on a car or is it being put on an ATV, 4 wheeler, etc?
Either will work. I would choose pureone myself, but I know that isn't one of your options, but for a few dollars more, I have found the Pureones To have better construction and filtration capability over the 2 you named already.
Good luck and post pics of whatever you decide to use!
Interesting I never knew there was a hate for puro classics here. All 3 of my vehicles are running them. The wife's buick running a rebranded promotive?? one I think ( local quick lube stock). I guess I'll start running Napa or Carquest.
You got a lot of catching up to do. Lots of reading and pics on here about them
Fram PH7317
14610 13
10241 11
14459 8
14460 5
20195 5
12222 2
14006 2
24651 3
10111 2
14477 1
24011 1
25247 1
25288 2
30001 1
Out of how many MILLION filters?
Not hate. More like disappointment. It is hard going from being a darling and then having what appears to be a run of bad filters for over a year (still ongoing so far). So it looks like their QC or standards dropped. If you produce [censored] and then it gets [censored], most folks will not notice (oh, well, it was [censored] to begin with). If you make something very dependable, then you start rolling out with the low-quality run, people get angry. However, what really lit a few torches and brought out the pitchforks was the complete lack of response from Purolator. They took the "Your filter failed, too bad for you. Your problems with our products are not a concern for us..." approach. People with multiple filter failures got the cold shoulder.
The sample size on BITOG is not in the millions so you cannot compare that way. You would have to know in the time frame of the listing of tears how many non-torn filters there were and then do the math.
Fram PH7317
14610 13
10241 11
14459 8
14460 5
20195 5
12222 2
14006 2
24651 3
10111 2
14477 1
24011 1
25247 1
25288 2
30001 1
Possibly millions!
Considering the small number of C&P filters posted on BITOG combined with the astronomical failure rate, the likelihood of hundreds of thousands of fails is quite possible. With our size of a community, any pattern of 60+ filter failing in an identical manner is worth taking seriously.
I'm still waiting for someone to provide some inkling of scientific analysis versus the typical redneck him-hawing that goes on around here. I expect to reach retirement before an actual six sigma analyst feels compelled enough to discredit the small sect of typical actors who bemoan a proven quality product.
Out of curiosity, what does it take before one bemoans a product? One failure? Two? Five?
I am also still waiting for someone to post an engine failure that was directly attributed to a purolator classic. Just the thought that their precious engine may or may not have had some extra particles running through the various channels of the engine throws so many in a right tizzy.
Those Purolator "failures" always look a little dubious to me. I would expect to see more localized collapsing of the media where the failure took place and much more of a blow through if oil was flowing through there for thousands of miles.
Neither, move over on the shelf to the Tough guard or even Ultra. The extra couple dollars is worth it and they are a better value. The several small holes are the oil inlet, not drain. Those holes are not an issue.
Do not deflect--answer the question. I think what puts people into a tizzy is paying for a product and seeing it perform in a substandard way--in some cases more than once so they were giving the product a fair chance. I had noted a few people posting tears, but still used a P1 and then it tore 3 times for me. I chose to spend my money more wisely and change brands.
