Take a flashlight and shine into filter.Oil filter off my friends 2012 Honda Odyssey with 295k miles. I think the filter looks great. Mobil 1 0w40 28,000 mile oci. 3.75 quarts top off. Will post uoa when it comes in. Mobil 1 0w40 and another FE7317 went back in/on.
He actually ran the oil for 28,000 miles? The top off oil volume probably helped, but still.Mobil 1 0w40 28,000 mile oci. 3.75 quarts top off.
That is 7K mi oil consumption rate.He actually ran the oil for 28,000 miles? The top off oil volume probably helped, but still.![]()
Wicking has started. Will update in a week@mt23 would you be willing to cut the paper off the end caps and take a few pictures of it stretched out? We would like to see what the filter caught.
Yes he did. Link to some previous used oil analysis on the van hereHe actually ran the oil for 28,000 miles? The top off oil volume probably helped, but still.![]()
In my observation of recent FE c&p anecdotes, one of the better/best looking bypass piece seal areas. And yet.......
This is the main reason he can put 28K miles on an OCI: "My friends 2012 Odyssey. He drives 50-70k per year mostly rural and highway."Yes he did. Link to some previous used oil analysis on the van here
My friends 2012 Odyssey. He drives 50-70k per year mostly rural and highway. His name is Kazu, the unit ID is Kazu Van, which is why it shows in comment section
Been using Mobil 1 0w40 the past few oil changes. This oci was with the api SP version and one of the quarts of top off may have been SN. Van had an ignition coil failure out of town and may have contributed to the uptick in iron blackstone noted. It was also 1.5 quarts low at time of oil change. He does not check the oil, I'm usually able to check it for him when our schedules fit.
The van does not have VCM disabled. Van had a...
- mt23
- Forum: Used Oil Analysis - Gasoline
There are gaps in ALL FE and similar filters.Leaf spring looks much better than most. Also a much smaller gap. These seem to be getting very inconsistent quality wise.
Interested to see the UOA, but may not be able to extrapolate much from that without context and concrete info from a single run as opposed to a trend that was already established.
