Formula Shell 5w20
North Carolina
FYI,
Advance Auto now carries Formula Shell 5w20. It's 2.99 a qt. Good oil from what I am reading here. How much different is it really from Pennzoil or QS?
+1 on the Good Oil
I'm sure it's fine, but @$15.00(approx)5qts., it's more expensive than many oils that I would consider better, including, but not limited to Pennzoil conventional, Motorcraft, Motorcraft 5000, Valvoline conventional, Valvoline MaxLife semi, and QS(at least as good)$10.50.
Price would need to be much lower to pique my interest.
Originally Posted By: breeves
FYI,
IIRC Pennzoil would have the best add pack of the three. I'm not sure where it stands with QS, it is a good oil. I'm currently finishing my final A-Rx rinse with it, no problems at all.
Seems like a really good deal for a Sophus product. Should be more than fine for a 3000k oci, right?
You could do 5K without a problem IMO!
Originally Posted By: Nickdfresh
The Target near me carries Shell oil for $2.39 a quart...
Never seen 5w20 FS @ Target. Might be now, but last I checked none. IMO, if given the choice I'd go QS for less and 5w20 everday @ Wally. JMO
Our Target (Pensacola Bayou Blvd) has carried it for a long time. Used to be only $1.99 per qt., but I think it has gone up to the low $2 range as Nick reports.
You should be able to find it for less than $2.99.
That seems to be the best conventional deal in quarts.
