Oil report is from Blackstone. I am checking for AF contamination. Used Exxon Superflow before this OCI. I did not change the oil when I took this sample. Blackstone suggested I "resample to monitor", and I "could run the oil longer if I wanted to".
al 1 4
ca 1503 2052
cr 0 1
cu 1 5
fe 3 19
pb 0 4
mg 0 1
mo 35 59
phos 566 772
pot 1 2
si 8 15
na 19 28
sn 0 1
zn 685 952
vis@210 62.8
FP 375 fuel tr
af ? water 0.0
insol 0.2
1 quart of hd40 is mixed with the 10w-30. Antifreeze is Dex-cool.
I am also mixing a little marine 2 cycle oil in the gas tank.
Can you tell from this oil report if I need to replace the intake manifold gasket?
Thanks, Joe
my UOA universal averagecode:
al 1 4
ca 1503 2052
cr 0 1
cu 1 5
fe 3 19
pb 0 4
mg 0 1
mo 35 59
phos 566 772
pot 1 2
si 8 15
na 19 28
sn 0 1
zn 685 952
vis@210 62.8
FP 375 fuel tr
af ? water 0.0
insol 0.2
Thanks, Joe
