Ford's CHT (cylinder head temp) sensor
D60
Colo
Does anyone know exactly how the PCM uses this? Specifically, I noticed on an '06 Expedition that after start-up the V(oltage) will read about 0.5 for anywhere from a minute to a couple minutes, even when you're up to temp. The F(arenheit) reading will say, for instance, 198* but show 0.5V, which wouldn't correlate.
This is a 5VREF so 1/2 volt is not ~198F.
But at some undetermined time the Voltage will jump to something more sensical, usually around 3.6V for the 198-201F range
I suspect the PCM is not supposed to actually look at the sensor immediately after start-up, potentially because of heat soak and I have to believe there's some latency in a "dry" sensor screwed into the head vs a sensor immersed in water flow.
If not, then maybe I should be chasing an electrical issue, but the PCM (and gauge) seem unconcerned during the brief periods of 0.5V readings after start-up.
Thoughts?
Here's the PIDs I was monitoring the whole time, although I didn't take the shot during a 0.5V timeframe:
Thoughts?
Here's the PIDs I was monitoring the whole time, although I didn't take the shot during a 0.5V timeframe:View attachment 298790
I don't think the sensor in the head is a dry sensor, it is still in coolant. The other sensor is probably in a hose connector or the block, I really don't have any idea its been a long time since I worked on anything domestic but IIRC didn't Ford have a phony temp dash gauge that always showed close to the middle that used a different sensor? Does this have something to do with that?
The engine should have a dry sensor. Most CHT on fords are dry sensors .
^^^^ Not sure about the V8 in the '06 Expedition, but Cylinder Head Temperature sensor in my '03 Ranger with the Duratec 2.3 liter was essentially a dry sensor.
  • Like
Reactions: D60
It's dry, I've replaced it before.
Ford did some annoying stuff on the modulars like moving the sensor around a bit and I think some of the earlier years (ie bubble bodies) had two: one for PCM, one for the gauge. But AFAIK '06 just used the CHT here for both engine mgmt and the gauge.
I think I'll fire up my wife's '08 F150 and see if the 0.5V behavior occurs. Curious to know.
Back in the day, the 10884 base number sensors were for the gauge since the cluster base number is 10849. The 12A648 was for the PCM since a PCM is 12A650, at least that was how I remembered it when people called. Now I just have to remember to sell intake manifold gaskets with a CHT on V engines.
Back when I replaced this one I cheated it under the intake. Not too bad really but you do have to have a flex head ratcheting wrench in 3/4" or 19
So yeah, the wife's '08 F150 displays the same behavior. At some point V goes from 0.5 - 0.59 to something in the 3.00's.
This seems to happen around thermostat temp but it's not a hard over/under, ie above or below 195* (I think factory may technically be 192*) is not a guarantee of being in the 0.5x or 3.xx range
Anyway I'm sure the behavior is normal but still curious exactly what the criteria/programming are/is
