sorry, I have tried the search, & cant seem to find the information I am looking for. I recently purchased a new 2018 F150 3.5 Ecoboost. I completed the first oil change early at 3900 kilometers, or around 2400 miles for you Americans. I though oil was pretty black in appearance for a new engine, & had a gassy fuel dilution odor. I sent a sample to Fluid Life in Edmonton for Analysis.
Once I get results back I will share them.
I replaced oil with a store Brand, (Canadian Tire Formula 1) Shell Manufactured Synthetic Oil, & a Baldwin Filter.
I am having trouble finding the specs for a Ford filter, efficiency rating, & concerned about the differences in bypass settings. I have heard from other sources that some feel that adding an aftermarket oil separator catch can is beneficial to preventing the intake valves from carbon buildup, & might install a Team RXP, dual valve RX catch can, or UPR 5030-221-1 separator in the future. Would be monitoring oil through analysis to log if there is any benefit, or all gimmick.
The following is all I have found for Fords filter specs, I have attached a Baldwin summary as well
Motorcraft FL-500S OIL FILTER SPECS
Part Number: 57502
Principal Application: Mazda Tribute, Ford Escape and Mercury Mariner (2009) w/ 3.0L engine - Ford Taurus, Edge, Mercury Sable w/ V6 3.5L mfg after 1/16/2009
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.09
Outer Diameter Top: 2.942
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Max Flow Rate: 10-12 GPM
Beta Ratio
Burst Pressure
Normal Micron Rating
Gasket Dim's: 2.753" OD x ID 2.397" ID x 0.25" Thick
The original oil filter from factory was a FoMoCo AA5E 6714 DA, what is the significance of the ***E/ ***Z as compared with the AA5Z-6714-A
Part Number: 57502
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.09
Beta Ratio
Burst Pressure
