Originally Posted By: oldmaninsc
440Magnum said:I've routinely gotten 18 MPG@ 70 MPH in our 08 Ram 1500 quad-cab (4.7L) and have gotten as high as 22 @ 70 a few times when the ambient temps were low enough that the AC cycled a lot. And that's over a whole tank of gas, not a spot reading on the trip computer, either. My advice is don't EVER judge performance of a class of vehicles by anything you rent from U-haul!
First you are comparing apples and oranges.
Comparing a Ram 1500 to an F-150? That's about as "apples to apples" as you can get.
Second - why does the fact that I rented from Uhaul have anything to do with it? UHaul pickups are all low mileage. The dealer said Uhaul only lets them keep the pickups for about a year and then they are replaced with brand new trucks.
Some of these trucks had under 5K miles on them, some had about 15K. Either way they all got about the same MPG, which also coincides with various family members/friends who have owned NUMEROUS F150's over the years!
My advice is not to comment on something that you know little about!![]()
Well, I've NEVER rented a U-haul vehicle that wasn't a beat-to-death pile of junk. Ever. But I won't debate the physical condition of the trucks- you had the trucks and you saw the odometers. But I do NOT think the mileages you reported are at all representative of a modern half-ton v8 truck. Not by about 3-4 mpg.
The unloaded Ecoboost in the test made a few forays into the 20-mpg range. That's good, but my point is that its not really outstanding for a modern half-ton V8 pickup, like our Ram or newer F-150s which routinely do 18-19 on the highway, and more than occasionally break above 20 mpg. It may be better in mixed driving, where our Ram peaks out at about 16 mpg- if the Ecoboost could turn in a consistent 20-22 under commuting (city/highway) conditions, I'd consider it a major improvement.
But my bottom-line point is that the real-world numbers that are popping up *so far* are only showing about a 2-5 mpg improvement over a V8 for the Ecoboost. I'm just not sure its worth the added complexity in the long run. Neat idea, neatest implementation I've seen yet, but smallish payoff. Now if it turns out that the Ecoboost lasts as long as a Dodge 4.7 or Ford 4.6 without any more maintenance, then the verdict will CLEARLY be that its the way to go. If its a shorter-life engine, then my personal opinion is that it needs bigger efficiency numbers to make it worth it.
But we'll see... they just haven't been on the market that long yet.
