OVERKILL
$100 Site Donor 2021
Originally Posted By: Trav
Hydraulic lash/lifters adjusters are in principal the same whether they are down inside the engine riding on top of the cam or OHC,the only difference is the missing push rods and location within the engine block.
I was expanding on the issue (as described earlier in the thread) as being related to the TIMING CHAIN TENSIONER, which the old pushrod motor DOES NOT HAVE. That's why I said it was completely different.
The same issues with sticking,bleed down and face wear are true of both types.On 4.6 and 5.4 V8 engines the ADBV is critical because the filter is horizontal,on this engine it isn't.
Nobody was talking about that, but I agree. As I said, my post was in relation to the tensioner and the pushrod motor not having one.
I would bet on the tensioner as the source of the noise which is common to all these motors,because they are fed by the oiling system they can get varnish in them and stick.
This seems to be the general consensus. I agree.
BTW for the poster who said the 427 was never used in a production ford.The Thunderbolt was a production car that used this engine.The Twisted Hemi 429 was used in Mustangs but a few did find their way into a small production of Cyclones.
http://musclecars.howstuffworks.com/classic-muscle-cars/1964-ford-thunderbolt.htm
Wrong 427. There were THREE variants of this engine, only ONE having overhead cams. The 427 SOHC was never a factory-fitted engine. Re-read what I wrote. I said the 427 SOHC was never factory-fitted, which is true.
There was the 427, 427 side-oiler and the 427 SOHC. The last one made the most power by a wide margin, had true hemispherical chambers, and is actually what the mod motors were partially based on. The Thunderbolt had either the normal 427 or the side-oiler, I don't remember which, but it didn't have the Cammer.
In regard to the BOSS 429, it was also apparently fitted into a couple Torinos (I've seen pictures, and this was the chassis Petty raced it in) but no official Ford serial numbers exist for these vehicles
