Originally Posted By: BBDartCA
75w90 and 50w trans fluids usually are very close in viscosity.
And even at even some lube OEMs, gl5 75w90 and 50w mt1 are the same lube but the latter has the EP add pack deleted. General statemement. Exceptions exist. Pleanty.
Getting back to the root of the OP's problem, which was his trans started having sticky shifts after a cold snap. I attribute this to the snake oil additive being used. Actually, appears to be a vegetable oil additive. Here is it's patent:
https://www.google.com/patents/US5282989...ved=0CBwQ6AEwAA
Patent ref from brochure:
http://www.lubegard.com/pdfs/GEAR_PS.pdf
They are not using vegetable oils.
They are using "derivatives" of vegetable oils.
Vegetable oils contain both acids and alcohols. They separate out the two components and use the acids.
They react these acids with special alcohols to get a new synthesized lubricant called an ester. They call these esters, "Liquid Wax Esters" or LXE.
Sorry, as I explained above, they are not.
The OP appears to have been using a high viscosity differential lube which is too thick for manual transmissions AND which did not have the necessary friction modification for manual transmissions.
Because the Lubegard "GEAR FLUID SUPPLEMENT" thinned out the differential fluid (it has the viscosity of ATF), it allowed slightly easier shifting.
BTW, the Lubegard "GEAR FLUID SUPPLEMENT" is for use in differentials, AND ONLY at a 10% dosage.
I think Drew was wise to go with the dedicated MTL.
