My infamous 2000 Ford Contour is at it again.
This time as I was on a 3 hr. drive back from a business trip, an 18 wheeler had a rear tire blowout and I swerved right and left to miss the big chunks of re-tread. I thought that I heard a small piece or two hit the undercarriage. About 1/4 mile later, the car starts surge, like it's running out of gas. I pull over and look underneath.
I see what looks like an o2 sensor wiring plug, still connected like it's supposed to be, but hanging below the chassis. Noting that it's not disconnected, I get back in and drive on.
For a while, the surging back and forth doesn't happen.
Then I get on the interstate from some state highways and as I get to around 75 mph it starts to surge again.
I pull over and check the tranny fluid. It looked to be about a quart low so I put in a quart of ATF. I get back on the road and I'm getting the surging again but it doesn't happen immediately. It's like it happens after about 10 minutes or so of high speed driving.
At one point it got so bad, I thought it had to be the fuel pump. The car was losing power and no matter how far I pushed the accelerator, it wouldn't pick up speed. Eventually the check engine light came on and it died. I waited on the shoulder and called AAA. AAA is a must when owning a Ford Contour. It's even issued as a standard equipment by the dealer.
So after about 15 minutes I decide to try to start it. It starts fine like nothing's wrong. I then drive the 20 miles back to my house.
We went out of town for T-Giving so yesterday when we got back, I disconnected the battery to reset the check engine light.
I drive it around today and no problem. No check engine light, no surge/stall/etc.
So, I'm wondering if when I swerved back and forth to miss those tire chunks if gas somehow got up into the gas cap and caused it to quit venting.
I should have taken it down to autozone to see what the codes were. If it happens again, I will.
What's your guess?
What's your guess?
