Ford C-Max Engine Coolant & Inverter Coolant Change
Georgia
I am looking at getting the Preston Platinum. I think I'm going to call and find out about their certifications for this coolant
I’d use the Prestone Platinum myself. Ford did say their new yellow coolant - also Prestone is OK for ones filled with Dex-Cool originally. Use the premix for the inverter, you want DI water ideally.
Thanks very much for that. I also ordered the Peak Yellow but I think the Platinum will be fine in the end. We needed more brake fluid this afternoon and the Prestone was among an amazing number of well-stocked brands at the Walmart.
I thought about the universals too. But I think spending $10 extra on an assured fit is the best choice in this situation.
