OVERKILL
$100 Site Donor 2021
I figured I'd give this a while to see if it persisted before putting together a thread on it.
As everyone knows, I swapped out two very high quality synthetic oils (Ravenol SSL 0W-40 and M1 EP 0W-20) in the Jeep and RAM for @High Performance Lubricants Super Car oils, both with Euro additive packages. However, we've owned many engines with MDS starting with our 2006 Charger R/T, 2014 Charger SRT-8, 2016 Grand Cherokee SRT...etc.
I've owned 3x SRT Grand Cherokees and they all have the same "rumble" from the MDS because you are inches away from the engine and it isn't very well insulated, so it's very easy to discern when it is on the MDS or not. The RAM, since it has active dampening (frame mounted harmonic devices designed to counteract the MDS rumble) has always been vastly less perceptible with only the exhaust note really being the cue, since it has a Borla system on it, which isn't exactly quiet, and the note changes when it drops into 4-banger mode.
I've run several different oils in my SRT vehicles including the Pennzoil SRT 0W-40, Mobil 1 FS 0W-40 and of course the Ravenol mentioned above. Every single one of them behaved the exact same, which one would expect.
So, you can imagine my surprise when, after I put in the HPL oil that the MDS became imperceptible on the Jeep. I mean completely. You cannot tell if it is on the MDS or not, since you can't hear the exhaust (factory exhaust). I was initially doubting myself on the matter, thinking well, this isn't possible. However, upon changing it in the truck, there was also a difference, even though you couldn't really feel much in the first place. So, after driving the Jeep for a while now with this oil, and this continuing to be the case, I've concluded that it must be the FM chemistry. I mentioned it to Dave and he kind of laughed and said "well, nobody is going to believe you" but at this point, I was like, well, I'm going to share it anyways.
I'll stress that nothing else has changed. Engine runs the same, sounds the same, oil pressure is the same, only difference appears to be the MDS operation.
Unfortunately, I don't have a VOA of this oil and I suspect some of what Dr. Rudnick has put together here is highly proprietary (@MolaKule could perhaps speculate) so I don't think we are going to get an answer on that. I do know that (since Dave is very forthcoming) that they use a variety of FM chemistries together, as certain combos have extremely good synergies, but it depends on the overall formulation as to what works best, which can only be determined with testing, which they of course perform. We are talking dimer moly, trimer moly and tungsten. Not sure if they also use titanium or not, I didn't ask. But basically, it is a complex FM development that is undertaken to determine what works best with a given base oil and additive package chemistry.
I would be very interested if somebody else with a 6.4L that has MDS would buy the same oil and see if their results are the same as mine.
EDIT: Per Wayne's request,
FM = Friction Modifier, these are compounds that reduce the coefficient of friction on surfaces, reducing drag and improving efficiency
MDS = Multiple Displacement System. This is a cylinder deactivation system that, using a mechanism inside the lifters, disables 4 of the 8 cylinders to improve economy
