So, I just bought a 2009 Forester.
I just ordered Redline 75w90 Gear Lube and a few tools to help me change out the differential fluids front and rear.
After reading what everyone posts about Subaru diffs, I expect to find some REALLY nasty fluid (full of metal) when I drain them. I assume they have never been changed and this 2009 Forester has 45K miles on the clock. So, I expect something scary to come draining out of them.
What do you guys think about attempting to clean up any residue after I let the diffs completely drain? I want to get as much of this crud out as possible before I pour in the Redline gear lube. Would you all consider it? If so, what should I use?
What I'm thinking of doing is either: A.) Leaving the fill and drain plugs out after the diff's drain, and squirt some fluid all around the inside of the diff's and let them drain again. Or, re-install the drain plug, fill with a fluid, let it sit for a minute, and then let it drain out. Then install my new gear lube.
Good idea? Am I thinking too much?
Lastly, if this sounds like a good idea, what "cleaning" fluid would you use? Some different ideas I have: Supertech (cheap) gear lube, MMO, carb cleaner, Seafoam, PCMO, Kerosene, etc. etc.
Sorry for the wrong post this morning....too much coffee and excited about servicing this Subaru.
