I did a PS flush/Amsoil synthetic ATF switch on my newest Pontiac Vibe today. In the past, I used to disconnect the return line and run the engine to pump the fluid through the system. It worked OK but the PS pump was never very happy during and after the flush.
So I decided to try one of the other methods mentioned here on BITOG, namely, leaving the engine off and simply turning the steering wheel lock to lock to "pump" the fluid through. I never thought it would work but it did!
It took about 4 lock to lock cycles and a few resevoir refills to completely purge the factory ATF from the system.
The nice part is I only used 1 quart total of expensive synthetic ATF, there was no mess from old fluid spraying all over the place and I never got any air in the system! After I hooked the return line back up, topped up the resevoir and started the engine, the fluid level never dropped....cool!
So if you have a car with an easily accessible PS return line, I highly recommend trying this method out.
