Flushed brake fluid.
Canuck - moved to —> California —> Texas —> ???
This is the second time in 6 years that the brake fluid was flushed.
Looks pretty good, but a bit dark. However, even though the fluid looked good, when I took out the bleeder screws, to clean the threads, there was a bit of corrosion on the front ones on the tapered ends, so there must've been some moisture in the system, probably from last brake service as I never bled the system.
Originally Posted By: ARCOgraphite
Looks like good whiskey!
Probably is just as deadly too
Either way, driving this morning the pedal was nice and firm. Before it used to soften up a bit, as the brakes got hot during the commute. I thought it was my imagination, but I guess my butt dyno was right for once.
