Flush out cooling system in the winter, or wait for warmer weather (reliably over freezing 24/7)
Why are you doing a flush ?
Is the vehicle overheating ?
Is the radiator dirty ?
Heater not working well ?
Coolant is supposed to be regularly changed out.
NO! This is routine maintenance.
NO! In fact it should be pretty clean. It's was replaced a few years ago.
YES! Thermostat was also replaced at some point as well.
Maybe flush is the wrong wording but more like this:
I want to get out the existing coolant which is a mix of the original red (or pink??) Toyota coolant and some green stuff added to replaced what was lost when the radiator/water pump/thermostat was replaced (on three separate occasions over the last 21 years), and switch to Peak 10X as I am switching al the vehicles I maintain to that. Only reason I didn't do this earlier is that I wanted to make sure that there were no leaks after I removed and replaced stuff, and now that I have just cleaned out the IAC and throttle body, I'm not anticipating having to touch the cooling system again for some time.
I'm only asking about running water to clean it out in cold weather.
I know......If you think you can flush it out in one day....go for it. Keep in mind tho if the outside temps get below freezing (32)F it could do some damage. That's why you should do a 50/50 flush this time of year.
