>Why are you doing a flush ?
Coolant is supposed to be regularly changed out.
>Is the vehicle overheating ?
NO! This is routine maintenance.
>Is the radiator dirty ?
NO! In fact it should be pretty clean. It's was replaced a few years ago.
>Heater not working well ?
YES! Thermostat was also replaced at some point as well.
Maybe flush is the wrong wording but more like this:
I want to get out the existing coolant which is a mix of the original red (or pink??) Toyota coolant and some green stuff added to replaced what was lost when the radiator/water pump/thermostat was replaced (on three separate occasions over the last 21 years), and switch to Peak 10X as I am switching al the vehicles I maintain to that. Only reason I didn't do this earlier is that I wanted to make sure that there were no leaks after I removed and replaced stuff, and now that I have just cleaned out the IAC and throttle body, I'm not anticipating having to touch the cooling system again for some time.
