Fluid recommendations for Mazda fnr5
WI
I've done a lot of searching but most of the info is dated.
I need atf that meets the M-V/M5 spec
I recently got a fusion with the Mazda automatic for a family member and would like to swap out the fluid before they start driving it.
The Mazda OEM fluid is ungodly expensive and if have to drive an hour or so to the dealer.
I've seen some use Transmax multi
And possibly the Mag1 multi
I see Idemitsu makes a Mazda spec fluid but I would need to order it.
Any alternatives with good results?
So here's something that's fun. According to Ford, the FNR5 fluid updates / supercedes to Mercon V.
Castrol Transmax ATF/CVT List Mazda M-V on the label:
https://www.walmart.com/ip/Castrol-...lon/5265054718?classType=VARIANT&athbdg=L1200
Here's another post on the subject:
What's confusing is the multi vehicle atf also shows it meets the M-V spec
Why would both the multi and cvt universal meet the specs being different application fluids?
The white bottle of lucas at the auto parts store states it meets mazda m-v on the back.
I personally have been using valvoline maxlife in my 2002 protege that calls for M-V and am at a happy 260k miles. No signs of slips or anything. One of my customers is at 350k on her 2006 mazda 3 with the same maxlife. We have been doing hers every 30k with a filter change every other fluid change since she bought it at 170k miles. No clue on any fluid changes before she bought it.
Well I got frustrated with not being able to find what I wanted and ordered the Idemitsu atf type m for Mazda transmissions from eBay
I was going to go with the mobil one multi atf but I couldn't find enough of it.
