I have always used wheel bearing grease between the bearing and rotor and the rotor and wheel. It seems to work well.
For some reason why, I like these better than the Permatex Purple grease. I use the Orange stuff on the face of the piston and on the backing plate of the shim. Thick and works well.I've used this on every brake related service or between any parts that I don't want sticking together. Good to 3,000F. Always worry that grease or anti seize might run if it gets hot.
Me too. It seems to last a long time too.A thin film of never seize between the hub and rotor and rotor and wheel has worked for me for many years with no problems or corrosion issues.
THIS plus also on the wheel studs/bolts (adjust your torques accordingly).A thin film of never seize between the hub and rotor and rotor and wheel has worked for me for many years with no problems or corrosion issues.
They have a new version called WoolWax that smells really good. I've undercoated three cars with it. Love the stuff.I go with thin smear of anti sieze.
Fluid film is... organic! There's no way to genetically engineer sheep into producing high temp lanolin.
That said it's great for the backside of brake backing plates and all the threaded alignment & front end stuff.
I always took my rear brakes mainly apart every fall to check and lube everything b4 winter.Then in spring again to clean all the winter salt and corrosion and crap off for summer. Never had any problems in 127,000 miles on my 05 Ram. I do the same to my 17 Tundra now.Saves a lot of headaches later.I know this is an older thread but I have a few observations. First fluid film is HEADQUARTERED in California. It originally was used in a super super thick formulation to coat Navy ships. Here in our area we have a product called PFC from Pennsylvania. Protection First Class its a lanolin product but from a central PA company.
Second, Eric is really nowhere near Buffalo NY. I Guess to a left coaster he is but he's actually in a sleepy little town along I86 and I-390 south of Rochester NY. All of NYs southern tier is very poor and depressed. AND VERY RUSTY..
3rd in my experience with rust and NY, never seize doesn't work real well but anything is better than zero. The best brake care is to "service" brakes EVERY year. By service I mean disassemble and be sure the pins are free, the pads slide freely in the brackets and even use a sander to take a slight amount off the pads. Even scuff the rotor a bit. Every truck I've owned has had an issue with pads stuck in brackets not only creating premature wear but loss of fuel mileage. Is it worth paying a tech, probably not but it really is a good idea. I just put about $400 (u-joint, rotor, hub, pads) in my right front wheel none of which had been necessary had I serviced it annually. If I had a local tech do thus it would be over $1000 per wheel.
And the hub doesn't get anywhere near hot enough for it to be an issue and if you sprayed it on so thick that it runs, well that is an application error.
I'm always worried about some of the thicker anti-seize causing the runout to be out of spec, although the times I've used it I've never had any problem. Just paranoia on my part.
