Fluid film fail on me today
LONESTAR state
Get off work this morning 6am was 27 degree , went out to unlock my truck, it open, but it wont shut, I look at the lock it was frozen, the fluid film was so thick, also have some ice on it too. I cant closed my truck door. lucky I have some de-icer spray, spray it on, let it sit and it finally let me lock the door, but since the fluid film is SO THICK, my car wont shut right. I think Imma wash the lock off with some carb or brake cleaner and going back to heavy duty silicon .
If in future my lock is frozen and my door wont shut, what the fastest way to unfroze the lock, I heard WD-40 work best, i havent use WD-40 in years.. Thanks
Originally Posted By: Klutch9
You really shouldn't use 'wet' lubricants in a lock cylinder. Aside from your issue, they also attract dirt.
A while back I saw a guys work for fluid film, he spray it on the door latch to prevent it from sticking or frozen during winter . That what I did
27 degrees isnt exactly cold. Fluid film is viscous and likely not ge right product for that, but I doubt its much different than white lithium.
Regardless, cleaning it out andvtrying something else is prudent.
that is what I did, clean its out and spray on something else. But dont know which lubricate to use
JHZR2, we consider 40 degrees to be wicked cold out here in California.
In California water freezes at 50*f.
In California, water doesn't exist
It was in the upper 70s here yesterday and people were wearing SWEATERS!
I've been using Fluid Film for almost 3 yrs on our fleet of trucks. I go through about a Case a month at each location. I have never had an issue with cold weather operation of components to aprox -40f and road salt/dirt. Lock, key cylinders, hinges and any other wear surface.
