Hello everyone, I am now the daily operations and fleet manager for a small delivery company.
We have all Ford’s, all but one is brand new. V8’s and V10’s for the larger vans. Over head cam, multi valve Ford Triton engines.
All of the van’s are parked inside a heated building when not in use.
They are all on the road 7 days a week, they are rode hard and put away hot.
Fully loaded every day, winter temps below zero, summer temps in the 90’s.
They only get shut off when parked for the night. Dirt roads. Tons of idle time, lots of foot to the floor wide open throttle.
I would like to do extended PM’s so a full synthetic is going to be best.
But I also need to keep costs down, and I need to maximize engine life. These van’s will be averaging 50,000 miles a year.
I will also need a grease to match the extended oil changes. There are 15 grease fittings on each van.
I am a fan of Shell Rotella T6 5w-40 but I do not know how well that will do in the Ford’s where 5w-20 is the factory recommended oil.
The used van has 200,000 miles on it, 2017 Ford 6.2L V8 and their mechanic used 10w30 and changed it every 5-6,000 miles. They bought cheap conventional, they have a history of blowing up the Ford engines, every 100,000 miles or so the V10’s have been dropping valves. I have no idea if that is a Ford issue or a lubrication issue.
I want to avoid this issue with my fleet.
So, my first choice is Rotella T6, second is Rotella Gas Truck 5w30, Castrol, then Kirkland Signature 5w30.
Castrol Syntec comes in many viscosities and variations, Magatec is stil full synthetic but less expensive than Syntec, which is less expensive than their Edge motor oil.
In my personal vehicles I use Castrol Syntec, 5w30 for my Toyota, and 5w-20 for my wife's Kia.
So, what is everyone’s thought/recommendation on this?
I am not a fan of Mobil 1, I am of the personal opinion that it is over priced and surviving on his history of being a good oil.
Also, fuel economy is not a concern. Cost’s and longevity are.
And yes I will be doing a SOS once the engines get a few miles on them.
