flat tappet recommendations
the past
what is the lowest viscosity mineral oil that you would consider using in a '70s flat tappet V8 engine.
it is an australian engine. ambient temps range from about 10 degrees C in winter to about 40 degrees C in summer
so far my searches here have shown 20w50, 15w40 and 10w30 are used by members here
what advantages could i expect changing from a 20w50 to a lower viscosity oil. the vehicle is a holden (GM) ute running std cams and compression, but is on LPG/petrol IMPCO dual fuel
many thanx, johnny
I have a 79 Dodge P.U. 2WD. 225 slant 6. I initially bought Rotella 15-40.( CJ-4 newest stuff) After reading many posts and charts from this site,I returned the dino Rotella and bought dino Castrol 20-50(SM rated),as it had higher zddp levels which is a necessary additive for flat tappet engines.Try to find an oil with higher levels of zinc and phosphorus. This seems to be getting more difficult.
Go with a quality 15-40 SM rated. Better cold start-up protection. Another option is to use Valvoline 20-50 racing oil if available. It contains enough zinc for flat tappet motors.
