Hello everyone,
I cam across this article from Blackstone Labs where they run ZDDP free oil (Aeroshell W65) in a flat-tappet GM 350 engine from 1984: article.
Now, I am actually surprised that no-one published the article before on this forum or perhaps I did a bad search. Here are the parameters of the test:
1. Oil used is Aeroshell W65 which is 30W grade, ZDDP free, it's viscosity is close to 10w30 grade
2. Engine is GM 350 flat tappet used 1984 Chevy truck
3. Two OCI done each with 16 month duration and around ~ 1900 miles (~ 3000 km)
4. ZDDP myth busted as there were no significant increase in metal wear numbers
Here are the actual numbers:
Thoughts, ideas?
Thoughts, ideas?
