IMHO any SM rated oil is fine for a flat tappet in it's stock form. However many engine builders feel that these *lower zddp* oils are causing cam failures, which I agree with to a certain extent. There are far to many variables in the real world to attribute these failures to one specific reason. Improper assembly, Cam MFG defects, underlying design issues, improper break-in, throttle happy motor heads, etc. But what about the "veterans" that are using the same procedure that they have been using for 50 years? And preformed hardness tests, used oil analysis etc? Somewhat suggestive?
To my understanding API no longer test for flat tappet performance, but A3 oils do? So would an A3 oil be a good choice for us flat tappet guys? What other choices are there?
IMO there are other adds than ZDDP that can handle Hi-Pro motors. Am I correct? If so which ones should we look out for? Boron, Antimony, MoDTC?
