I am just a dumb oil user with an old flat-tappet auto engine, street driven only. I have headaches from reading all the posts about reduced levels of ZDDP (Zn Pos.) in new SM rated API oils and there effect on flat-tappet wear.
Forget about break-in for the moment. Forget about racing and motorcycles.
Below is a post from the Rennlist forum and it’s url below. As copied below, Bob Olree says reduced levels of ZDDP in SM is not an issue for flat tappets (I assume after break-in).
There is also another url below linking to a report on development of the GroupIII test at GM with partners.
My question is: Are reduced levels of ZDDP in SM rated oils really an issue for flat tappets or NOT ?
JasonAndreas
Technical Guru
Rennlist Member
12/4/06
Chris,
If you have access to SAE papers at work read, "How much Zdp is Enough".
I referenced it from, "At our September chapter meeting, there was discussion of a magazine article which purported that new engine oils are short on an additive called ZDDP which, among other things, acts as an anti-wear lubricant. The article contends that ZDDP’s anti-wear properties are needed in older engines in particular, such as the collector cars which many of our Chapter members own. Fortunately, Chapter member Jerry Garfield was also at our meeting, and took a copy of the article back to the GM Tech Center and shared it with Bob Olree, a co-worker and Powertrain engineer. Here is what Bob had to say on the subject:
“In developing the ILSAC GF-4 ( API SM) passenger car engine oil standards, the subject of backwards serviceability was addressed by the ILSAC/OILCommittee. The current standard contains two flat-tappet engine tests, the Sequence IVA and IIIG. The Sequence IVA addresses low temperature cam and follower scuffing and the Sequence IIIG addresses high temperature wear. The engine used in the Sequence IIIG test is converted from the production roller-follower valve train to a flat-tappet valve train. These tests are included to insure that older flat-tappet engines are protected. The ILSAC/OIL Committee and its member companies (OEMs, oil, and additive) went to great lengths to be sure that older engines are protected by these latest oils.
ZDDP is a multi-functional additive. It is first and foremost an anti-oxidant, secondly an anti-scuff, thirdly an anti-wear, and lastly an anti-corrosion additive. The reason that it can be reduced from the peak levels that it once was used at is that ashless anti-oxidants have been developed which can replace it.
Flat tappet camshafts have a tendency to scuff during break-in. ZDDP is very effective in controlling break-in scuff. In my view, EOS should only be used as an assembly aid in rebuilding flat-tappet engines to address this break-in scuffing. Once an engine is broken in, it needs very little ZDDP to protect it. Please see the SAE paper I wrote on this subject. When camshaft scuffing and wear were first encountered in the early 1950s it was discovered that ZDDP, at the level found in current ILSAC GF-4 oils, was very effective in controlling these issues.
As with almost things in this world, a little bit of ZDDP is good but more is not necessarily better.”
The EOS (Engine Oil Supplement) mentioned above is a GM product sold at GM dealers under part number 1052367. It is a pre-lube for use when replacing camshafts, lifters, some rocker arms, etc. In the GM parts catalog there is a Precaution: Not recommended for use as an additive to engine oil."
Source:
http://forums.rennlist.com/rennforums/showthread.php?t=315506&page=2&pp=15
Development Report:
www.astmtmc.cmu.edu/docs/gas/sequenceiii/procedure_and_ils/IIIG/Sequence%20IIIG%20Research%20Report%2002-24-04.pdf
