FL500s (with even more glue!)
Excess glue breaking loose is not a good thing. It can easily make it through the bypass valve and into the engine. Thanks for the c&p!
The choice of oil filter is more important than ever now that so many brands have cheapened their filters and added sloppy quality assurance and inherent defects (leaks). It's reaching a point where engines are put at risk.
Hey @TheOilWizard. I hope you don’t mind me hijacking your thread for a minute. Adding my pics as well. Most concerning is the loose glue up near the bypass valve area and inside (clean side) of the tube. On a positive note, at least the louvers looked good 😆😂. Absolutely done with Motorcraft. I realize if this was a huge issue, there would be 5.0 engines, as well as others, dropping left and right. That’s not the point. This is unacceptable. I shot a quick 10 sec. vid of how easy the glue comes of but apparently I need to do my homework on how to upload it.
Great pics thanks. The glue is 100% getting through the bypass and into the engine….
@ZeeOSix
The date code is 2024. I always put mileage and date on the can with sharpie. Tried cleaning the sharpie off with brake-clean to read the rest of code and yep…you guessed it, remaining date code came off. 😂😆😂😆
So there’s that!
So true @Glenda W. , unfortunately.
It’s been in the low teens here lately in NC mornings. My OCI’s are 5k max on Mobil 1 Extended Performance or Valvoline Extended Protection.
(Save it everybody. I do 5k because I want to 😂😆)
Seeing the sloppy glue on these MC filters had me concerned about bypass events. Not from excess delta p from filter loading, but from that initial start up with the oil being thicker. Albeit the bypass event is typically quick and short, it’s a bypass event nonetheless. So I decided to cut open my MC from my last change to see for myself.
Motorcraft boasting about how their bypass valve is up top, thus preventing any dirty oil getting pulled up is a joke now. No, instead your **** glue is getting let through!
What I'd worry about is that debris getting into and blocking VCT screens and similar. Note the talk at time 0:35 regarding debris from the oil filter (torn media, and this crap glue coming off would also be a concerned).
Note at time 0:54 they show a Motorcraft filter with torn media ... you can see the center tube through the torn media, lol.
Some have reported finding some of that glue in their drain pan too when doing an oil change, so that means it had to go through the bypass valve at some point.
Yep, discovered that in my research Z.
Thanks @OVERKILL. Big fan of Donaldsons as Diesel is my background and am employed by large Diesel/Truck OEM.
I did research that particular part number, however they seem to have a similar glue issue as MC. The vid below is 2 years old so they may have cleaned up their act.
Donaldson P577066
Stills below from vid:
