Fiskars 8lb maul.
North Carolina
Thought I would try a newer maul. It really does absorb shock. It splits really well. Dry cherry in one whack. Hickory took a bit more. Being a wider head , it's not quite as accurate at hitting the same mark , I might not be used to it yet.
But I really like it.
I have that exact model. I only break it out for the big stuff...for normal sized splitting, I use a smaller hybrid axe, as I can swing it longer and faster.
it is a maul, not an axe. I've posted about those before; reviews indicate it is the "light sabre" of wood splitting.
I would carefully inspect the metallurgy; i found one with significant casting/forging flaws prior to purchase. Needlesstosay, not hitting anything with that.
I saw some reviews where the maul head split at the bolt. I won't be using it as a hammer for wedges, i have a sledge for that.
I'm using it to stay in shape, I'm trying to keep from feeling older.;)
Yeah, getting old kinda sucks. I do have a 16lb sledge so maybe I should use it to pound on some tires like those cross-fit guys do. That would be a good punishment for myself the next time I bring home a box of doughnuts.
Spasm3: growing up in the country and using a wood burner, I always had split all our firewood. Great workout and I still do it when at brothers house 👍🇺🇸
I find the Fiskars Super splitting axe (4 1/2 lb) can split most everything. Getting to where I will break in one of my rebuild chain saws by ripping the gnarly stuff rather than pounding it into splinters.
