Ok.
02 Nissan frontier.
Pennzoil platinum 5-W30.
Mobil 1 filter. 185k miles. Avg 250 miles a week. Mixed, but mostly rual.
Ok. Now. I never even knew about used oil analysis untill I found this forum. So here's my questions.
I just changed the oil from.. what ever was in it to the PP last week. There was tons of sludge. So I ran a gunk 5 min flush just before changing the oil.
It worked great.
Than I replaced it with PP.
(I'm a penz fan)
So I'm gonna stick with the brand, but. If I'm correct, I should not run this oil change long, because of the flush that was probably left in there.
So how long till I change it?
3k miles? Or sooner?
My over all results I want is 10k mile oil changes. So what filter should get me there?
Is PP capable of this do you think?
And I ordered a used oil analysis kit. It is my thinking that there is no sense in doing a used oil analysis on this oil, but the next oil change. Is that right?
And if so, than, how long should I go on the PP before I send off a used oil analysis sample. Also what added tests should I get? I'm going with blackstone.
I think PP should b able to get me 10k. If not maybe PU? I want to exhaust all options of the PENNZOIL brand before giving up on it. Hence the used oil analysis.
Any advice would be appreciated.
02 Nissan frontier.
It worked great.
(I'm a penz fan)
