Originally Posted By: Sw296inchblue
Hello, just picked up a 2014 Regal 2.0T awd. First turbo for us. I'm wondering what I need to know about this engine / drivetrain ? I "think" this is the LTG variant of the 2.0T turbo engine. Curious about which oils have faired well in this engine ? Also if anyone knows about the trans case or differentials in this Vehicle ? Info at the buick forums is pretty thin. Thanks
Hi SW,
I have a similar engine: 2.0 LNF Turbo with a 5L40e trans(made in France) and a Getrag LS differential(made in Germany). Buick did use some of these but not sure when or what.
My oil cap says Mobil 1 5w30 on it. I like Mobil 1 but did switch to 5w30 Pennzoil Ultra (gray bottle). It most certainly brought the engine temp down about 5 degrees. It is just a slicker oil and since these turbos run 220 - 230 degrees on a hot day I am looking for all the help I can get, so yes I am staying with Pennzoil Ultra for this car.
GM wants us to use Dexron VI for the auto transmission. I just bought a case of 12 Chevron full synthetic on Amazon for $52.86 delivered. I like it according to the
specs.. You will need to monitor your temperatures to determine what is best for you. Also check out the Kendall Dexron 6, good stuff.
Also because of the heat issues on a turbo I have had to flush my power steering
fluid. GM does not make a fluid that will handle this kind of heat. Pontiac themselves had suggested Redline PS fluid for this problem. From now on Redline is all that I will use on any of my PS units. It really does do the trick.
I still have differential issues. Cadillac just changed it out with the grape scented stuff but I will have to add some Lubegard LS when I change out the transmission fluid.
Hope I wasn't too long winded
