96 cavalier, 76k miles on original ATF.
I got the procedure down already,
Warm up vehicle
unbolt pan
clean pan
replace filter
clean magnet
replace seal
bolt it back together
add new fluid
the car calls for Dex III and at Wallmart i saw Pennzoil ATF tat was DEX II,III,ect ect. compatible.
Will it work on my car without problems?
I understand DEX III is not being sold anymore
i believe i will be able to remove 2 quarts so i probably have to repeat all this about 3 times to completely drain and refill the transmission?
Should i use regular, dino ATF, or go with some better stuff like Amsoil ATF, or M1?
Warm up vehicle
unbolt pan
clean pan
replace filter
clean magnet
replace seal
add new fluid
