SolusUmbra
Thread starter
- Joined
- Jan 19, 2026
- Messages
- 34
I have a 1988 Ford Ranger 2.0L and I’ve been running 10-30 full synthetic for as long as I’ve had the truck. The last time it went to the mechanic he put in 10-30 conventional without asking me (also had a brand new unopened bottle on the back). I’m kind of scarred now to trust anyone else changing my oil, as it just doesn’t run the same as it used to and now for the first time in my looking into trying to see if I can do it myself.
However I’m coming a-crossed some questions.
1. I have very weak hand strength/grip, what will be the best type of tool to have for removing the oil filter?
2. What brand of cheap oil filer is best?
3. Does my truck use a crush washer or gasket? When I looked online at O’Reillys it shows a 16mm bolt with some kind of blue gasket, but the one on my truck is 13mm or at least the last time it went checked it was, mechanic might of changed that to…
4. also the last time it tried to remove that plug I wasn’t able to do it, I overfilled
what options do I have if I can’t move it again? I bought a breaker bar but it might be too big to fit under the truck.
Thanks in advance for any tip, tricks, and advice
