It appears to say "Guess" with the last "s" covered by the remnants of a sticker, so not exactly a reassuring thing to place on a cap, or a switch which it also might be lol.What does it say on top of that knob/ cap?
I’ll try to get back to double check still at the park…It appears to say "Guess" with the last "s" covered by the remnants of a sticker, so not exactly a reassuring thing to place on a cap, or a switch which it also might be lol.
Yeah that would make much more sense!Guest for air ride seat? Long shot.
Makes 100% senseGuest is the manufacturer’s name for high end battery disconnect switches.
Tradition as much as anything I believe. Axles and diffs were always in pints.The units they use are odd.
Why is one 35 quarts but another 35 pints?
That is the battery switch. Driver turns it on as they get into the seat.What does it say on top of that knob/ cap?
You must work with some small trucks.That's a small oil sump. The x15 Cummins in the trucks at my work take 11 gallons.
they must be Irish or somethingThe units they use are odd.
