OVERKILL
$100 Site Donor 2021
Originally Posted By: clinebarger
You going to put a cam in it? It makes 403HP stock, which is pretty darn good by itself IMHO.
I have to, My Gen 3 (P59) PCM cannot control the VVT Cam Phaser, & the Cam Sensor Relutor is 4X, Where I need a 1X signal. The only 1X Cam Gear available is a 3-bolt design vs the 1-bolt VVT Cam.
Gotcha. Sounds like you've got a fair bit of work ahead of you but the results should definitely be worth it
