Hi folks, recently I bought a subaru and I found its standard oil filter bypass value is 23PSI, which is way higher then normal Mobil 1 or Fram utra filter.
So I did some research and my conclusion is: it's ok to use low bypass value filter, if its threshold flow rate is large enough.
why?
Bypass will take effect in some cases:
1.cold weather start, in which you really need some oil to circulate, I'm not gonna focus on this.
2.high rpm, in which engine saturate filter flow capacity and differential pressure builds up util hits bypass value
Let's assume now for German cars or subaru that their engine indeed push oil aggressively to filter, if filter's flow capacity is good enough to handle, then it will be fine because no differential pressure will be built up; as rpm grows, finally it will hit the threshold. So it's not just a number of bypass pressure, it's indeed a function between maximum flowrate capacity and bypass value.
So, let's use a methodology of extremecy. Suppose you have a really low value bypass filter but your flowrate is supreme (which is impossible) that it can handle any oil flow from the engine, then bypass valve will never be triggered. This is indeed the case when you don't have a filter at all. But on the other opposite, even you have a high bypass filter (say 23) but flowrate maximum is easily reached, it will be the same as is only 5...
Please correct me if I'm wrong
why?
