It's unlikely that 20 minutes would plug any filter, even during break in, unless a very poor and dirty job of assembly has been done (no insult intended, merely making a point).
Also, when I start an engine for the first time, I fill the cooling system with hot water, so the engine starts semi-warmed up. Also, don't run a really heavy oil, or a good flowing, high VI oil so that you won't have to worry about bypassing.
Along the lines of what oldhp said, a high efficiency, high flow synthetic filter will do everything you want and in combination with a high VI oil, bypassing is unlikely. Also, a syn filter has very high capacity (often double an equivalent sized cellulose or cellulose blend filter) so it would address all your concerns.
If you want to be really anal, run a bypass filtration system during the break-in.
I presume this 20 minutes will be the 3000 rpm cam break-in period.
Finally, if you followed good clean assembly procedures on engine assembly and have installed a cam break-in additive, in conjunction with a high efficiency filter (may I suggest a less expensive Fram Ultra vs the RP), I think a 20 minute OCI is a bit of overkill. That would be especially true if you installed a roller cam. But it's your wallet after all and I understand the need to pamper the new "baby." I'm not emotionally involved, so it's easy for me to be the voice of practicality ( : < )!
