Maybe you like looking at pictures and all you need to see is the results.
Filter companies in fact do a lot more anlysis of failed filters than you would ever expect.
Filter companies do extensive testing on products before consumers get the finished product. Not unlike what Mobil 1 has been doing for months before they choose what they want in their new filter coming out. They and Champ have over a million miles of test data. And the filters aren't on just new engines.
Engine companies do extensive testing such as hot weather, cold weather, endurance, etc.
But you've seen some pictures..the filter is crap..and that's all that matters.
Not whether the pressure regulating valve failed. Not that the vehicle has high mileage and has had poor maintenance. Not that the oil pan is full of sludge. Not that the owner has gone way beyond the change interval. Not that there might be water or coolant in the oil. Or any other possibility.
Nope..you've seen the pictures. That's enough for you.
But yet you want a filter company to build a bullet proof filter and when someone posts pics with NO data about it's use, somehow a filter company is supposed to mysteriously have a clue as to why the filter failed.
Accident investigators use more than a picture of a car crash to analyse what happened. And in the end it just might be driver error. But we will never know if a component of the car caused the crash without the data by just looking at a picture.
If all it took were pictures for filter companies ( or car companies) to know what went wrong, they might as well fire a bunch of useless engineers and sell off a bunch of test equipment. Somehow I doubt they will...
But at the end of the day..you can complain all you want, the filter meets or exceeded OEM specs.
Regardless of any picture posted. So something should tell you..even if you won't admit it..that all those years and years of test data by OEM's and filter companies under all kinds of conditions, that the
OEM specs are designed to protect the engine under all kinds of conditions. So when a filter is not mismanufactured, the possibility of a correctly manufactured filter "causing" the problem is minute. It is the
conditions the filter is exposed to that causes the filter to look like it does after it's use. Simple as that is.
Hard for you and others to take on board, apparently.
