Quote:
Humm ... so if the max spread was only 2 PSID and in relief mode, then it sounds like that filter's bypass was set to 2 psi? That's what it sounds like. Maybe the gauges weren't very accurate. Sounds like the true delta P gauge you used below is an accurate assessment.
No. The normalized "out of relief" PSID was about 2PSI or less. It's the relief event that caused all appreciable PSID to exist to begin with.
It was the same (mostly) with a used filter with 9k on it. The difference being that when in a relief event, you moved more toward the filter's bypass setting, and could "surge" the flow to produce a "flare" of PSID until the oil warmed more. Since you were effectively using a smaller filter (aged) ..the "absolute" properties of the flow at visc were detectable.
Quote:
That's good data ... shows the filters (even the dirty one) flowed good enough to basicallynever go into bypass mode, or at least very briefly on cold start. What kind of filters were they, and was the engine revved up significantly to produce some good flowrate through the system?
The new one was a tea cup sized PureOne (same as PH3614). The 9k was a PH16 sized PureOne.
I'll try and find the link to my post on it. The images are gone due to Sony's image hosting going bye-bye. Unfortunately, I relied on the graphs to speak my thousand words with a few open ended statements .."I saw THIS" type stuff.
Basically I swapped out the dual gauges for the differential gauge. I think you could detect a minor twitch upon start up, but it was so slight, if at all, you could attribute it to your imagination. I really was sorta disappointed that I saw nothing. The two gauges, at least, provided something to look at.
When I took the images, I put 15w40 oil ..and had an overnight temp in the subfreezing level. The starting temp was 27F. My digital temp gauge didn't start reading until 70F ..so
(I upgraded the analog to a digital).
I can only describe the transitions as sorta a "phase shift" (and correction) of sorts. If you understand anything about inductive circuits .. the voltage leads the current for a brief time. In a DC circuit, the inductor itself creates its own impedance to the flow (it does this in AC, as well - but ..) ..so it appears like an open circuit for a brief time. After 5 time constants, it's a straight piece of wire.
In the same conceptual view, the max pressure (voltage) is being applied to the circuit ..but the flow (current) takes a bit to catch up.
You're reading your meter across the filter in place of the inductor.
This is an abstract view that doesn't directly apply. It would require some massaging and some allowances. That is, you could nitpick it if you wanted to ..but look at it as where I'm trying to take you ..and not in offering you something to dismantle.
