That's a decent looking filter cutter for the price.Dokili 66490 Oil Filter Cutter,Oil Filter Cutting Tool Fits Filters Up To 5 1/2 Inch Diameter red https://a.co/d/ai4irc1
Ya it looks pretty hefty, but when I went on Amazon, it wanted to make it a "subscribe & save" item.... So..... does that mean it won't last? LOL.Thanks for the tip. Just ordered one, currently has a 5% discount, so price comes out to be $26.75 - $1.34 = $25.41 before tax.
Should be able to click the "One-time purchase" button. The 77750 cutter should work good too.Ya it looks pretty hefty, but when I went on Amazon, it wanted to make it a "subscribe & save" item.... So..... does that mean it won't last? LOL.
I ordered the cheaper one on Amazon, the infamous 77750 model, which has dozens of sellers offering on eBay. $19.89 on Amazon
Ya, I knew that, I was wondering why it suggested it in the first placeShould be able to click the "One-time purchase" button. The 77750 cutter should work good too.
My screen automatically showed "one-time purchase". Maybe you buy some other stuff on a subscription so it automatically chose that option for you, lol.Ya, I knew that, I was wondering why it suggested it in the first place. The 77750 looks like the one I've caught a glimpse of in Whip City Wrencher's (or others') vids.
You can probably just remove the threaded rod and bend it back straight. The cutting wheel block can be made tighter by adjusting its retaining screw on the bottom. Tighten it enough to shore up the block, but still allow it to slide in the slot.The one problem is the threaded rod is bent. It binds through half of the rotation, the cutter wheel holder rocks side to side, and up & down, the down movement causing the binding.
So, in the name of science, I have a FRAM Ultra XG2 here with a dent in it that I'm not going to use so I've decided to cut and post. I've previously used a sawsall to cut them open and it's a huge PITA, so I bit the bullet and bought the Proform oil filter cutter tool:
https://www.summitracing.com/parts/pro-66490
I paid $111 Canadian for it through Amazon, should have it tomorrow.
What is everybody else using to cut their filters?
Ya I'm gonna return it, & see if the next one is any better.....You can probably just remove the threaded rod and bend it back straight. The cutting wheel block can be made tighter by adjusting its retaining screw on the bottom. Tighten it enough to shore up the block, but still allow it to slide in the slot.
It could be worse, lol.Ya I'm gonna return it, & see if the next one is any better.....
Nice bonus that it comes with a spare cutting wheel and couple of Allen wrenches.I got this one from eBay.
$23 and free shipping.
Appears to be a Long acre knock off, works well, I have probably cut open 7 or 8 filters so far.
https://www.ebay.com/itm/1258552273...CMI5DT4S9u&var=&widget_ver=artemis&media=MORE
I have this:The Longacre brand is like $70-$80 USD wherever I see it. There are a lot of off brands on Amazon & eBay for around $20 USD. They any good? I won’t be cutting a ton of filters but still I want it to work.
Anyone use the cheap ones?
FWIW, the knock-off is made in ChinaIs this one any good?
Is there any difference between a real Longacre and the knock-offs?
Should we be loyal to Longacre as a company? I mean, are they a USA manufacturer?
Ya I read complaints by people who don’t know how to use a pipe/tubing cutter. LolI have this:
https://a.co/d/bULeGb9
Works great. Don't press down too hard at first, gradually increase the cutting edge
