I got a FH680V 23hp kawasaki that has around 1000hrs on it. Here in Louisiana it gets really hot in summer time. I have always used mobil 10w30 oil from day one. Will it hurt anything to change oil grades to 15w40 mobil fleet?
Originally Posted By: zrxkawboy
What does Kawasaki recommend?
I can't seem to find the recommendation directly from Kawasaki, but this is from the manual for a John Deere 727A zero turn mower, which uses this engine
I use Rotella T6 in the 20HP Kawasaki in my John Deere 425. A 15w40 HDEO should work great if it's never used in below freezing temps.
If 10w30 is working great why change?? If you want something good you might want to look towards Castrol Edge 0w30 (German Castrol). It is nearly a 40 wt and has good cold cranking viscosity. It has been proven to work very well in OPE especially air cooled.
