Very knowledgeable people on here!
1988 Ferrari Testarossa.
What coolant ? Mind boggling number of antifreeze types available these days !
Bearing in mind want a product easily available in Europe or UK. Halfords is near by.
Have Maxol Ultra antifreeze concentrate & deionised water which I use in 1960s Jaguar 4.2s & various 70s Ford V8s etc , 96 Fiat Cinquecento.
Would be convenient to use same in Testarossa.
Tech data sheet for Maxol a/f includes....
B.T.C. 2E ( Seems to be British tech classification, ethylene glycol)
MEG (Mono ethylene glycol) based inorganic.
NO nitrites, amines or phosphates (NAP free)
Has borate & silicate.
Corrosion protection of all metals & alloys.
When I do some reading elsewhere about silicates in a/f it says it may attack gaskets...
Definitely don't want headgaskets deteriorating.
I see some recommendations for G11, G12, G12+ which are apparently silicate free...
A coolant which requires less frequent changing would also be nice !
Most of the cars only cover a few hundred miles annually. I drain some coolant every few years & refill with new.
I'm not seeing any rust usually on draining.
Out of interest do the corrosion inhibiting additives deteriorate more in the same time period with a lot of use / hot & cold cycles than with low annual mileage ?
Thanks in advance for any constructive input !
