Car: 1996 Honda Civic LX
Engine
16Y7
Brand:Fel-Pro
Head Gasket Set part# HS9915PT1
1. Cylinder head gaskets
2. Intake manifold gaskets
3. Intake manifold plenum gasket
4. Exhaust manifold gaskets
5. Valve cover gaskets
6. Valve cover grommets
7. Valve cover semi-circular plug
8. Spark plug tube seals
9. Push rod cover gaskets
10. Push rod cover grommets
11. Camshaft oil seals (OHC)
12. Valve stem seals
13. Water outlet gasket
14. Thermostat housing gasket
15. Distributor mounting gasket
16. Air cleaner gasket
17. TBI mounting gasket
18. Throttle body mounting gasket
19. Fuel injector seals
20. Air bypass gasket
21. Air pump gaskets
22. Exhaust flange gaskets
23. Heat riser gasket
24. Choke tube gasket
25. EGR valve gaskets
These are the items that maybe in the Fel-Pro head gasket set, I need help narrowing down which items would be in the head set for my engine as I prefer to order OEM Honda parts online. I will be ordering from oemautopartz.com/honda as they were the cheapest I found from the 4 online sites i compared. if you guys have suggestions on OEM Honda dealer online would be nice as well.
I had a bad experience with a Fel-Pro head gasket which was redeemed by using OEM Toyota head gasket on my 2000 Toyota Celica GT-S, this is the reason why I will be using OEM gaskets/piston rings for all my cars from now on.
I will be using this for an engine rebuild with a friend come summer time.
Thank You for any help!
Engine
Brand:Fel-Pro
