Farpoint Farms : Alignment at home with this product
Have a different brand but same idea. The ONLY thing you should be using those for is after a suspension job getting the toe set so front wheels are perpendicular to each other to get you to the alignment shop without scrubbing your tires up. Let the shop get the thrust angle correct which is incredibly difficult to impossible at home.
When I first bought the mazda in early 2020, it had a bad lower ball joint, passenger side. The only replacement was a new control arm and I gave it a garage alignment after installing a new lower control arm and also replacing the struts and sway bar links. Tracks perfectly and tire wear is even (honestly I can't even tell if the tires are wearing). It's quite possible to use this and get things right at home with some thought, effort and perseverance.
